A trust region method based on interior point techniques for nonlinear programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Programming Année : 2000
Richard H. Byrd
  • Fonction : Auteur
Jean Charles Gilbert
Jorge Nocedal
  • Fonction : Auteur
An algorithm for minimizing a nonlinear function subject to nonlinear equality and inequality constraints is described. It can be seen as an extension of primal interior point methods to non-convex optimization. The new algorithm applies sequential quadratic programming techniques to a sequence of barrier problems, and uses trust regions to ensure the robustness of the iteration and to allow the direct use of second order derivatives. An analysis of the convergence properties of the new method is presented.
RR-2896.pdf (385.08 Ko) Télécharger le fichier
inria-00073794 , version 1 (24-05-2006)
Paternité - Pas de modifications
Richard H. Byrd, Jean Charles Gilbert, Jorge Nocedal. A trust region method based on interior point techniques for nonlinear programming. Mathematical Programming, 2000, 89, pp.149-185. ⟨10.1007/PL00011391⟩. ⟨inria-00073794⟩
195 Consultations
4316 Téléchargements
