Jumps and Diffusions in Volatility: It Takes Two to Tango - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
We consider the following stochastic differential equation for describing financial data evolution: $$ dX_t = b(t, X_t)¸dt + \sigma(t) h(X_t)¸dW_t, \qquad X(0)= x. $$ with a stochastic volatility $\sigma(t)$ (e.g. the combination of a diffusion and a jump process). First we prove the existence and positiveness of the solution of a Cox-Ingersoll-Ross type stochastic differential equation with time varying coefficients, which is a special case of our model. Next, from observation on $X_t$ at times $t_i$ (with non regular sampling scheme), we propose a non-parametric estimator for the volatility (optimal in a certain way). We show its point-wise convergence and its asymptotic normality. After, we propose an estimator for the volatility jump times and prove a Central Limit Theorem. Finally the application of these estimators to the BTP futures (Italian ten year bond futures) and Lira 1 month deposit Eurorates seems to confirm the adequacy of the proposed model.
RR-2848.pdf (811.07 Ko) Télécharger le fichier
inria-00073843 , version 1 (24-05-2006)
  • HAL Id : inria-00073843 , version 1
Renzo G. Avesani, Pierre Bertrand. Jumps and Diffusions in Volatility: It Takes Two to Tango. [Research Report] RR-2848, INRIA. 1996, pp.34. ⟨inria-00073843⟩
83 Consultations
97 Téléchargements
