Synthesizing Verdant Landscapes using Volumetric Textures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
Fabrice Neyret
Volumetric textures are able to represent complex repetitive data such as foliage, fur and forests by storing one sample of geometry in a volumetric {\em texel} to be mapped onto a surface. This volume consists in samples of densities and reflectances stored in voxels. The texel can be prefiltered similarly to the mip-mapping algorithm, giving an efficient rendering in ray-tracing with low aliasing, using a single ray per pixel. Our general purpose is to extend the volumetric texture method in order to provide a convenient and efficient tool for modeling, animating and rendering highly complex scenes in ray-tracing. We illustrate our method with verdant landscapes such as forests and lawns. In our previous work, we have dealt with the multiscale volume representation and texel animation. In this paper, we show how to convert usual 3D models into texels, and how to render texels mapped onto any mesh type. Solving these two issues makes the method usable for a designer.
Autre [cs.OH]
RR-2846.pdf (597.42 Ko) Télécharger le fichier
inria-326-synthesizing_verdant-600x450_1Mbit.mp4 (16.49 Mo) Télécharger le fichier
Format : Vidéo
inria-00073845 , version 1 (24-05-2006)
  • HAL Id : inria-00073845 , version 1
Fabrice Neyret. Synthesizing Verdant Landscapes using Volumetric Textures. [Research Report] RR-2846, INRIA. 1996. ⟨inria-00073845⟩
138 Consultations
299 Téléchargements
