Higher Order Multifractal Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
We extend the multifractal analysis to the description of the distribution of the $n$-th order correlation of singularities. For this purpose, new multifractal spectra are defined, and some general relations between them are given. We finally perform explicitcomputations in the case of deterministic multinomial measures, and show that the multifractal formalism does not hold for correlations on this class of measures.
RR-2796.pdf (365.31 Ko) Télécharger le fichier
inria-00073894 , version 1 (24-05-2006)
  • HAL Id : inria-00073894 , version 1
Robert Vojak, Jacques Lévy Véhel. Higher Order Multifractal Analysis. [Research Report] RR-2796, INRIA. 1996. ⟨inria-00073894⟩
58 Consultations
105 Téléchargements
