CAPM, Risk and Portfolio Selection in «Stable» Markets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
Our main purpose in this paper is to derive the generalized equilibrium relationship between risk and return under the assumption that the asset returns follow a joint symmetric $\alpha$-stable distribution, with $1< \alpha <2$. In order to justify such an investigation, we start by empirically evidencing the fractal structure of stocks market through extensive tests of self-similarity and stability. These tests allow us to model price changes with $\alpha$-stable distributions. We then show that equilibrium rates of return on all risky assets are functions of their {\bf covariation} with the market portfolio. The «stable» CAPM highlights a new measure of the quantity of risk which may be interpreted as a generalized beta coefficient.
RR-2776.pdf (491.24 Ko) Télécharger le fichier
inria-00073916 , version 1 (24-05-2006)
  • HAL Id : inria-00073916 , version 1
Lotfi Belkacem, Jacques Lévy Véhel, Christian Walter. CAPM, Risk and Portfolio Selection in «Stable» Markets. [Research Report] RR-2776, INRIA. 1996. ⟨inria-00073916⟩
167 Consultations
332 Téléchargements
