Cooperation of Decision Procedures for the Satisfiability Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
Constraint programming is strongly based on the use of solvers which are able to check satisfiability of constraints. We show in this paper a rule-based algorithm for solving in a modular way the satisfiability problem w.r.t. a class of theories $Th$. The case where $Th$ is the union of two disjoint theories $Th_1$ and $Th_2$ is known for a long time but we study here different cases where function symbols are shared by $Th_1$ and $Th_2$. The chosen approach leads to a highly non-deterministic decomposition algorithm but drastically simplifies the understanding of the combination problem. The obtained decomposition algorithm is illustrated by the combination of non-disjoint equational theories.
Autre [cs.OH]
RR-2753.pdf (281.01 Ko) Télécharger le fichier
inria-00073939 , version 1 (24-05-2006)
  • HAL Id : inria-00073939 , version 1
Christophe Ringeissen. Cooperation of Decision Procedures for the Satisfiability Problem. [Research Report] RR-2753, INRIA. 1995, pp.19. ⟨inria-00073939⟩
75 Consultations
174 Téléchargements
