On the Validation of Robotics Control Systems Part II: Analysis of real-time closed-loop control tasks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1995
Eduardo Castillo
  • Fonction : Auteur
Paul Freedman
  • Fonction : Auteur
In the framework of the {\sc Orccad} system, periodic and multi-rate control laws are implemented in terms of a set of computing tasks to be executed under a real-time operating system. Simulations and experiments demonstrate that partially synchronizing such tasks can improve the practical performance of the implementation. In this paper, we examine the consequences of introducing such synchronisation in terms of two temporal problems which may occur and how they may be detected using Petri net modeling. We conclude with some guidelines about how to add such synchronisation to design deadlock free and efficient real-time periodic control laws.
Autre [cs.OH]
RR-2720.pdf (170.89 Ko) Télécharger le fichier
inria-00073973 , version 1 (24-05-2006)
  • HAL Id : inria-00073973 , version 1
Daniel Simon, Eduardo Castillo, Paul Freedman. On the Validation of Robotics Control Systems Part II: Analysis of real-time closed-loop control tasks. RR-2720, INRIA. 1995. ⟨inria-00073973⟩
84 Consultations
66 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
