On the Formal Specification of Group Membership Services - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
The problem of group membership has been the focus of much theoretical and experimental work on fault-tolerant distributed systems. This has resulted in a voluminous literature and several formal specifications of this problem have been given. In this paper, we examine the two most referenced formal specifications of group membership and show that they are unsatisfactory: One has flaws in the formalism and allows undesirable executions, and the other can be satisfied by useless protocols.
RR-2695.pdf (273.64 Ko) Télécharger le fichier
inria-00073995 , version 1 (24-05-2006)
  • HAL Id : inria-00073995 , version 1
Emmanuelle Anceaume, Bernadette Charron-Bost, Pascale Minet, Sam Toueg. On the Formal Specification of Group Membership Services. [Research Report] RR-2695, INRIA. 1995. ⟨inria-00073995⟩
67 Consultations
118 Téléchargements
