A New Algorithm for Finding Minimum-Weight Words in a Linear Code: Application to Primitive Narrow-Sense BCH Codes of Length~511 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
Anne Canteaut
Florent Chabaud
  • Fonction : Auteur
An algorithm for finding small-weight words in large linear codes is developed. It is in particular able to decode random [512,256,57]-linear codes in 9~hours on a DEC alpha computer. We determine with it the minimum distance of some binary BCH codes of length~511, which were not known.
Autre [cs.OH]
RR-2685.pdf (336.32 Ko) Télécharger le fichier
inria-00074006 , version 1 (24-05-2006)
  • HAL Id : inria-00074006 , version 1
Anne Canteaut, Florent Chabaud. A New Algorithm for Finding Minimum-Weight Words in a Linear Code: Application to Primitive Narrow-Sense BCH Codes of Length~511. [Research Report] RR-2685, INRIA. 1995. ⟨inria-00074006⟩
248 Consultations
370 Téléchargements
