The Law of the Euler Scheme for Stochastic Differential Equations : II. Convergence Rate of the Density - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
Denis Talay
  • Fonction : Auteur
  • PersonId : 833429
In the first part of this work~\cite{Bally-Talay-94-1} we have studied the approximation problem of $\ee f(X_T)$ by $\ee f(X_T^n)$, where $(X_t)$ is the solution of a stochastic differential equation, $(X^n_t)$ is defined by the Euler discretization scheme with step $\fracTn$, and $f(\cdot)$ is a given function, only supposed measurable and bounded. We have proven that the discretization error can be expanded in terms of powers of $\frac1n$ under a nondegeneracy condition of Hörmander type for the infinitesimal generator of $(X_t)$. In this second part, we consider the density of the law of a small perturbation of $X_T^n$ and we compare it to the density of the law of $X_T$: we prove that the difference between the densities can also be expanded in terms of $\frac1n$. \noindent{\bf AMS(MOS) classification}: 60H07, 60H10, 60J60, 65C05, 65C20, 65B05.
Autre [cs.OH]
RR-2675.pdf (606.45 Ko) Télécharger le fichier
inria-00074016 , version 1 (24-05-2006)
  • HAL Id : inria-00074016 , version 1
Vlad Bally, Denis Talay. The Law of the Euler Scheme for Stochastic Differential Equations : II. Convergence Rate of the Density. [Research Report] RR-2675, INRIA. 1995, pp.30. ⟨inria-00074016⟩
378 Consultations
652 Téléchargements
