On Integer Chebyshev Polynomials
We are concerned with the problem of minimizing the supremum norm on [0,1] of a nonzero polynomial of degree at most $n$ with integer coefficients. We use the structure of such polynomials to derive an efficient algorithm for computing them. We give a table of these polynomials for degree up to 75 and use a value from this table to answer an open problem and improve a lower bound from~[3]
