Particle and cell approximations for nonlinear filtering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
Fabien Campillo
Frédéric Cérou
  • Fonction : Auteur
  • PersonId : 970892
François Le Gland
  • Fonction : Auteur
  • PersonId : 832228
Rivo Rakotozafy
  • Fonction : Auteur
  • PersonId : 874497
We consider the nonlinear filtering problem for systems with noise--free state equation. First, we study a particle approximation of the a posteriori probability distribution, and we give an estimate of the approximation error. Then we show, and we illustrate with numerical examples, that this approximation can produce a non consistent estimation of the state of the system when the measurement noise tends to zero. Hence, we propose a histogram--like modification of the particle approximation, which is always consistent. Finally, we present an application to target motion analysis.
Autre [cs.OH]
rr_2567.pdf (530.87 Ko) Télécharger le fichier
inria-00074114 , version 1 (24-05-2006)
  • HAL Id : inria-00074114 , version 1
Fabien Campillo, Frédéric Cérou, François Le Gland, Rivo Rakotozafy. Particle and cell approximations for nonlinear filtering. [Research Report] RR-2567, INRIA. 1995. ⟨inria-00074114⟩
156 Consultations
68 Téléchargements
