Semantics of Recovery Lines for Backward Recovery in Distributed Systems - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Reports (Research Report) Year : 1995
This paper addresses the definition of {\it recovery lines} in the context of backward recovery whose aim is to cope with failures in distributed sytems. A general framework that allows for several semantics of recovery lines is introduced. Key notions such as {\it missing messages} and {\it orphan messages} are precisely defined and their impact on the definition of consistency of recovery lines is carefully analyzed. Basic mechanisms such as local checkpointing, messages identification and (optimistic or pessimistic) messages logging are then discussed as an illustration of (coordinated or uncoordinated) checkpointing protocols.
Domains
Other [cs.OH]
RR-2468.pdf (331.26 Ko) Télécharger le fichier
Dates and versions
inria-00074207 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00074207 , version 1
Cite
Jerzy Brzezinski, Jean-Michel Hélary, Michel Raynal. Semantics of Recovery Lines for Backward Recovery in Distributed Systems. [Research Report] RR-2468, INRIA. 1995. ⟨inria-00074207⟩
107 View
205 Download
Share
