On the pathwise optimal Bernoulli routing policy for homogeneous parallel servers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1994
A long-standing conjecture on the optimal Bernoulli routing policy is proven to be true. For the case of equal exponential service times it is shown that splitting equally among the queues minimizes the departure times in a stochastic pathwise sense. A new technique is used, showing that certain distributional properties related to Schur convexity propagate forward in time.
Autre [cs.OH]
RR-2443.pdf (206.26 Ko) Télécharger le fichier
inria-00074232 , version 1 (24-05-2006)
  • HAL Id : inria-00074232 , version 1
Ger Koole. On the pathwise optimal Bernoulli routing policy for homogeneous parallel servers. [Research Report] RR-2443, INRIA. 1994. ⟨inria-00074232⟩
36 Consultations
157 Téléchargements
