A new intrinsic characterization of the principal type schemes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
Eric Duquesne
  • Fonction : Auteur
Jacques van de Wiele
  • Fonction : Auteur
The purpose of this article is to establish a new intrinsic characterization of the principal type schemes (or pts's for short) of the approximate normal $\lambda$-terms (or approximate normal forms). This is done by defining a correspondance between cut-free proof nets, $\beta$-normal $\lambda$-terms and their principal type schemes, and better, by defining a correspondance between approximate cut-free proof nets, approximate normal terms and their principal type schemes.
Autre [cs.OH]
RR-2416.pdf (280.61 Ko) Télécharger le fichier
inria-00074259 , version 1 (24-05-2006)
  • HAL Id : inria-00074259 , version 1
Eric Duquesne, Jacques van de Wiele. A new intrinsic characterization of the principal type schemes. [Research Report] RR-2416, INRIA. 1995. ⟨inria-00074259⟩
127 Consultations
70 Téléchargements
