Prototyping of VLSI Components from a Formal Specification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1994
We present a trajectory from formal specification to component, which can be used to prototype applications which combine off-the-shelf components and custom hardware, provided they meet the constraints of Synchronous Data Flow. The formal specification allows us to prove that custom components will be correctly synchronized in a system context. We first introduce VLSI Synchronous Data Flow, elaborate the constraints it imposes, and define functions relevant to constructing a system. Then we describe the construction of a simulation model. Finally, we develop a component for motion video coding in VHDL, starting from a formal specification.
Autre [cs.OH]
RR-2363.pdf (407.83 Ko) Télécharger le fichier
inria-00074315 , version 1 (24-05-2006)
  • HAL Id : inria-00074315 , version 1
Roderick Mcconnell. Prototyping of VLSI Components from a Formal Specification. [Research Report] RR-2363, INRIA. 1994. ⟨inria-00074315⟩
87 Consultations
360 Téléchargements
