Infinitesimal Brunovsky Form for Nonlinear Systems with Applications to Dynamic Linearization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1994
We define the ``infinitesimal Brunovsky form'' for nonlinear systems in the infinite-dimensionnal differential geometric framework devellopped in ``A Differential Geometric Setting for Dynamic Equivalence and Dynamic Linearization'' (Rapport INRIA No XXXX, needed to understand the present note), and link it with endogenous dynamic linearizability, i.e. conjugation of the system to a linear one by a (infinite dimensional) diffeomorphism.
RR-2313.pdf (331.22 Ko) Télécharger le fichier
inria-00074360 , version 1 (24-05-2006)
  • HAL Id : inria-00074360 , version 1
Eduardo Aranda-Bricaire, Claude-H. Moog, Jean-Baptiste Pomet. Infinitesimal Brunovsky Form for Nonlinear Systems with Applications to Dynamic Linearization. [Research Report] RR-2313, INRIA. 1994. ⟨inria-00074360⟩
Relations
175 Consultations
252 Téléchargements
