Grobner bases of toric ideals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1994
We study here \grobner\ bases of ideals which define toric varieties. We connect these ideals with the sub-lattices of $Z^d$, then deduce properties on their \grobner\ bases, and give applications of these results. The main contributions of the report are a bound on the degree of the \grobner\ bases, the fact that they contain Minkowski successive minima of a lattice (in particular shortest vector), and the algorithm (derived from Buchberger algorithm), which starts with ideal of polynomials with less variables than usual
Autre [cs.OH]
RR-2224.pdf (211.21 Ko) Télécharger le fichier
inria-00074446 , version 1 (24-05-2006)
  • HAL Id : inria-00074446 , version 1
Loïc Pottier. Grobner bases of toric ideals. [Research Report] RR-2224, INRIA. 1994. ⟨inria-00074446⟩
146 Consultations
557 Téléchargements
