Fast and efficient Generation of Loop Bounds
Current loop generation techniques are based on Fourier-Motzkin pairwaise elimination, which is known to be very memory - and computation - intensive. In this paper we explore an alternative way : the use of parametric linear programming, which allows to separate the computation of distinct loop bounds and leads to a parallel algorithm for loop generation.
