On the multisearching problem for hypercubes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1993
We build on the work of Dehne and Rau-Chaplin and give improved bounds for the multisearch problem on a hypercube. This is a parallel search problem where the elements in the structure S to be searched are totally ordered, but where it is not possible to compare in constant time any two given queries q and q'. This problem is fundamental in computational geometry, for example it models planar point location in a slab. More precisely, we are given on a n-processor hypercube a sorted n-element sequence S and a set Q of n queries and we need to find for each query q [??]Q its location in the sorted S. Note that one cannot solve this problem by sorting S[??] Q, because every comparison- based parallel sorting algorithm needs to compare a pair q, q' [??]Q in constant time. We present an improved algorithm for the multisearch problem, one that takes 0(log n(log log n)3) time on a n-processor hypercube. This essentially replaces a logarithmic factor in the time complexities of previous schemes by a (log log n)3 factor. The hypercube model for which we claim our bounds is the standard one, with 0(1) memory registers per processor, and with one-port communication. Each register can store 0(log n) bits, so that a processor knows its ID.
Autre [cs.OH]
RR-1990.pdf (231.68 Ko) Télécharger le fichier
inria-00074682 , version 1 (24-05-2006)
  • HAL Id : inria-00074682 , version 1
Mikhail J. Atallah, Andreas Fabri. On the multisearching problem for hypercubes. [Research Report] RR-1990, INRIA. 1993. ⟨inria-00074682⟩
51 Consultations
103 Téléchargements
