Tools for correct DSP synchronization
Software tools for assuring proper synchronization of real-time digital systems targeted at high-throughput applications are presented. These tools depend on the Signal synchronous language to express timing relations. The tools are presented in the context of a data-flow environment. Tools and environment support the use of externally defined functional blocks for rapid prototyping and easy insertion of new models of those functional blocks. We present 34 Mbit/sec video coding as a sample application using our tools.
