A Hierarchical approach for shape optimisation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1993
We consider the gradient method applied to the optimal control of a system for which each simulation is expensive. A method for increasing the number of uknowns, and relying on multilevel ideas is tested for the academic problem os shape optimization of a nozzle in a subsonic or transonic Euler flow.
Autre [cs.OH]
RR-1868.pdf (474.1 Ko) Télécharger le fichier
inria-00074805 , version 1 (24-05-2006)
  • HAL Id : inria-00074805 , version 1
François Beux, Alain Dervieux. A Hierarchical approach for shape optimisation. [Research Report] RR-1868, INRIA. 1993. ⟨inria-00074805⟩
58 Consultations
147 Téléchargements
