Flow control of production lines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1993
The paper addresses the flow control problem in production lines composed of a series of machines separated by buffers. We assume that the production capacity of each machine is constant and the demand is known over the whole problem horizon. Backlogging is not allowed. The flow control problem consists in adjusting the production of the machines in order to minimize the total cost incurred by holding work in process and finished products. Properties of the optimal solutions are proposed. Based on these properties, we propose a simple analytical solution.
Autre [cs.OH]
RR-1865.pdf (551.71 Ko) Télécharger le fichier
inria-00074808 , version 1 (24-05-2006)
  • HAL Id : inria-00074808 , version 1
Ahmedou Haouba, Xiaolan Xie. Flow control of production lines. [Research Report] RR-1865, INRIA. 1993, pp.15. ⟨inria-00074808⟩
113 Consultations
42 Téléchargements
