Accuracy of distributed timestamps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1992
Celine Valot
  • Fonction : Auteur
Various timestamping mechanisms has been provided in order to characterize the partial order between events occuring in a distributed computation. Using the order induced by such timestamping mechanisms, one can reasonn about causal or concurrent relation-ships between events. However comparisons between timestamps can induce false assumptions on these relationships. The order induced by the timestamps is not always the existing partial one in a distributed execution. It is in these terms that we study the accuracy of three timestamping mechanisms, showing the type of compromise (space-accuracy tradeoffs) one has to make when using them.
Autre [cs.OH]
RR-1804.pdf (938.86 Ko) Télécharger le fichier
inria-00074868 , version 1 (24-05-2006)
  • HAL Id : inria-00074868 , version 1
Celine Valot. Accuracy of distributed timestamps. [Research Report] RR-1804, INRIA. 1992. ⟨inria-00074868⟩
30 Consultations
31 Téléchargements
