Robust and efficient implementation of the Delaunay tree - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1992
Olivier Devillers
In this paper, we present some practical results concerning the implementation of the algorithm described in (DMT) which computes dynamically the Delaunay triangulation of a set of sites in the plane in logarithmic expected update time. More precisely, we show that the hypotheses of non degenerate positions can be dropped and the problem of precision can be treated correctly.
RR-1619.pdf (607.64 Ko) Télécharger le fichier
inria-00074942 , version 1 (24-05-2006)
  • HAL Id : inria-00074942 , version 1
Olivier Devillers. Robust and efficient implementation of the Delaunay tree. [Research Report] RR-1619, INRIA. 1992, pp.11. ⟨inria-00074942⟩
143 Consultations
194 Téléchargements
