On efficiently characterizing solutions of linear diophantine equations and its application to data dependence analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1992
Olivier Temam
  • Fonction : Auteur
  • PersonId : 830062
Harry Wijshoff
  • Fonction : Auteur
In this paper we present severals sets of mathematical tools for characterizing the solutions of linear Diophantine equations. First, a number of methods are given for reducing the complexity of the computations. Thereafter, we introduce different techniques for determining the exact number of solutions of linear Diophantine equations. Finally, we present a method for extracting efficiently the solutions of such equations. For all these methods the main focus has been put on their applicability and efficiency for data dependence analysis.
Autre [cs.OH]
RR-1616.pdf (1.02 Mo) Télécharger le fichier
inria-00074944 , version 1 (24-05-2006)
  • HAL Id : inria-00074944 , version 1
Christine Eisenbeis, Olivier Temam, Harry Wijshoff. On efficiently characterizing solutions of linear diophantine equations and its application to data dependence analysis. [Research Report] RR-1616, INRIA. 1992. ⟨inria-00074944⟩
83 Consultations
82 Téléchargements
