HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Rates of convergence of Newton type methods for variational inequalities and nonlinear programming
Abstract : This paper presents some new results in the theory of Newton type methods for variational inequalities and their application to nonlinear programming. A condition of semi-stability is shown to ensure the quadratic convergence of Newton's method and the superlinear convergence of some quasi-Newton algorithms, provided the sequence defined by the algorithm exists and converges. A partial extension of these results to nonsmooth function is given. The second part of the paper considers some particular variationnal inequalities with unknowns {x, l) generalizing optimality systems. Here only the question of superlinear convergence of {xk} is considered. Some necessary or sufficient conditions are given. Applied to some quasi-Newton algorithms they allow to obtain the superlinear convergence of {xk}. The application of the previous results to nonlinear programming allows to strenghten the know results, the main point being a characterization of the superlinear convergence of {xk} assuming a weak second-order condition without strict complementary.
Complete list of metadata
https://hal.inria.fr/inria-00075298
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 5:53:57 PM
Last modification on : Friday, February 4, 2022 - 3:23:55 AM
Long-term archiving on: : Tuesday, April 12, 2011 - 10:24:12 PM
Identifiers
  • HAL Id : inria-00075298, version 1
Collections
Citation
J. Frederic Bonnans. Rates of convergence of Newton type methods for variational inequalities and nonlinear programming. [Research Report] RR-1260, INRIA. 1990. ⟨inria-00075298⟩
Share
Metrics
Record views
220
Files downloads
33
