Performance analysis of a transfer line with unreliable machines and finite buffers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1989
This paper examines the performance analysis of a transfer line with unreliable machines and finite buffers. All machines have the same processing times. We propose a new decomposition method which decomposes a line into a set of two-machine lines. A sufficient set of equations is established to find performance measures such as production rate and average buffer levels. A simple iterative algorithm is then proposed to solve these equations. We also prove that the set of decomposition equations has a unique solution and that the proposed algorithm converges to that unique solution. Experimental results show that the proposed algorithm leads to a good solution.
RR-1089.pdf (1.05 Mo) Télécharger le fichier
inria-00075470 , version 1 (24-05-2006)
  • HAL Id : inria-00075470 , version 1
Xiaolan Xie. Performance analysis of a transfer line with unreliable machines and finite buffers. [Research Report] RR-1089, INRIA. 1989, pp.24. ⟨inria-00075470⟩
76 Consultations
106 Téléchargements
