Some results on feedback stabilization of a one-link flexible arm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1992
The aim of this report is to exhibit a class of stabilizing feedback laws for a structurally undamped one-link flexible arm with control applied at one extremity. A finite-dimensional model of the arm, corresponding to a discretization in space, is first considered. The arm is then modeled by a classical partial differential equation, no finite dimensional approximation being made in the control analysis. In both cases, stability of the closed-loop system is proven, using a Lyapunov method and applying Lasalle's principle. The pratical significance of the proposed results is commented upon and illustrated by simulation experiments.
Autre [cs.OH]
RR-1682.pdf (345.67 Ko) Télécharger le fichier
inria-00076905 , version 1 (29-05-2006)
  • HAL Id : inria-00076905 , version 1
Sylvie Icart, Juliette Leblond, Claude Samson. Some results on feedback stabilization of a one-link flexible arm. [Research Report] RR-1682, INRIA. 1992. ⟨inria-00076905⟩
155 Consultations
126 Téléchargements
