A General scheme for token and tree based distributed mutual exclusion algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1992
In a distributed context, mutual exclusion algorithms can be divided into two families according to their underlying algorithmic principles: those which are permission-based and those which are token-based. Within the latter family a lot of algorithms use a rooted tree structure to move the requests and the unique token. This paper presents a very general information structure (and the associated generic algorithm) for token-and treebased mutual exclusion algorithms. This general structure does not only cover, as particular cases, several known algorithms but also allows to design new algorithms well suited to topology requirements.
Autre [cs.OH]
RR-1692.pdf (1002.34 Ko) Télécharger le fichier
inria-00076927 , version 1 (29-05-2006)
  • HAL Id : inria-00076927 , version 1
Jean-Michel Hélary, Achour Mostefaoui, Michel Raynal. A General scheme for token and tree based distributed mutual exclusion algorithms. [Research Report] RR-1692, INRIA. 1992. ⟨inria-00076927⟩
135 Consultations
137 Téléchargements
