Correctness of automated distribution of sequential programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1992
In this paper, we prove that the data-driven parallelization technique, which compiles sequential programs into parallel programs for distributed memory parallel computers, is correct. We define a model based on labeled transition systems, and we prove, from the chosen compilation rules, the confluence of all possible behaviours of the parallel programs we obtain, in spite of asynchronism due to the communications. We also show that this model is powerful enough to prove the correctness of various optimizations of the basic compilation mechanism.
Autre [cs.OH]
RR-1724.pdf (1.1 Mo) Télécharger le fichier
inria-00076963 , version 1 (29-05-2006)
  • HAL Id : inria-00076963 , version 1
Cyrille Bareau, Benoit Caillaud, Claude Jard, René Thoraval. Correctness of automated distribution of sequential programs. [Research Report] RR-1724, INRIA. 1992. ⟨inria-00076963⟩
188 Consultations
106 Téléchargements
