Construction of d-dimensional hyperoctrees on a hypercube multiprocessor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1992
We present a parallel algorithm for the construction of the hyperoctree representing a d-dimensional object from a set of n(d-1) dimensional hyperoctrees, representing adjacent crossections of this object. On a p-processor SIMD hypercube the time complexity of our algorithm is O(F(m;p) log p log n) where m is the maximum of input size.
Autre [cs.OH]
RR-1752.pdf (162.05 Ko) Télécharger le fichier
inria-00076992 , version 1 (29-05-2006)
  • HAL Id : inria-00076992 , version 1
Franke Dehne, Andreas Fabri, Mostafa Nassar, Andrew Rau-Chaplin, Rada Valiveti. Construction of d-dimensional hyperoctrees on a hypercube multiprocessor. [Research Report] RR-1752, INRIA. 1992. ⟨inria-00076992⟩
213 Consultations
362 Téléchargements
