Watermarking attack: security of WSS techniques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
Most of watermarking techniques are based on Wide Spread Spectrum (WSS). Security of such schemes is studied here in adopting a cryptanalysis point of view. The security is proportional to the difficulty the opponent has to recover the secret parameters, which are, in WSS watermarking scheme, the private carriers. Both theoretical and practical points of view are investigated when several pieces of content are watermarked with the same secret key. The opponent's difficulty is measured by the amount of data necessary to estimate accurately the private carriers, and also by the complexity of the estimation algorithms. Actually, Blind Source Separation algorithms really help the opponent exploiting the information leakage to disclose the secret carriers. The article ends with experiments comparing blind attacks to these new hacks. The main goal of the article is to warn watermarkers that embedding hidden messages with the same secret key might is a dangerous security flaws.
Cayre04-IWDW.pdf (202.28 Ko) Télécharger le fichier
inria-00083194 , version 1 (29-06-2006)
  • HAL Id : inria-00083194 , version 1
François Cayre, Caroline Fontaine, Teddy Furon. Watermarking attack: security of WSS techniques. International Workshop on Digital Watermarking, Oct 2004, Seoul, South Corea, South Korea. pp.171--183. ⟨inria-00083194⟩
284 Consultations
254 Téléchargements
