Scalable Tree Aggregation for Multicast - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Alexandre Guitton
Joanna Moulierac
IP multicast is not widely deployed yet over Internet. This is mainly due to the forwarding entries scalability and control explosion problems. In this paper, we propose an algorithm called STA (Scalable Tree Aggregation) which reduces the number of trees by allowing several groups to be aggregated to the same tree: the less trees, the less forwarding entries and the less control messages to maintain trees. STA performs faster aggregations than previous aggregation algorithms by evaluating fewer trees for each group, while keeping the same performance. We show the scalability and the fastness of STA by extensive simulations and we compare its performance to the previous algorithm.
rapport.pdf (155.62 Ko) Télécharger le fichier
inria-00084802 , version 1 (10-07-2006)
  • HAL Id : inria-00084802 , version 1
Alexandre Guitton, Joanna Moulierac. Scalable Tree Aggregation for Multicast. ConTEL, Jun 2005, Zagreb, Croatia. ⟨inria-00084802⟩
211 Consultations
171 Téléchargements
