HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Rendering Grass in Real Time with Dynamic Light Sources
Abstract : Since grass is very abundant on the Earth's surface, it is an important element of natural 3D scenes. Real-time realistic rendering of grass has always been difficult due to the huge number of grass blades. Overcoming this geometric complexity usually requires many coarse approximations to provide interactive frame rates. However, the performance comes at the cost of poor lighting quality and lack of detail of the grass. In this report, we describe a grass rendering technique that allows better lighting and parallax effect while maintaining real-time performance. We use a novel combination of geometry and lit volume slices, composed of Bidirectional Texture Functions ({BTF}s). {BTF}s, generated using a fast pre-computation step, provide an accurate, per pixel lighting of the grass. Our implementation allows the rendering of a football field, covered by approximately $627$ million virtual grass blades, with dynamic lighting, shadows and anti-aliasing in real-time. The creation of arbitrary shaped patches of grass is made possible using our density management.
Document type :
Reports
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/inria-00087776
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, August 2, 2006 - 10:49:17 AM
Last modification on : Friday, February 4, 2022 - 3:22:08 AM
Long-term archiving on: : Monday, September 20, 2010 - 4:40:13 PM
Identifiers
  • HAL Id : inria-00087776, version 2
Citation
Kadi Bouatouch, Kévin Boulanger, Sumanta Pattanaik. Rendering Grass in Real Time with Dynamic Light Sources. [Research Report] RR-5960, INRIA. 2006, pp.36. ⟨inria-00087776v2⟩
Share
Metrics
Record views
471
Files downloads
1402
