Gene Regulation in the Pi Calculus: Simulating Cooperativity at the Lambda Switch - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Transactions on Computational Systems Biology Année : 2006
We propose to model the dynamics of gene regulatory networks as concurrent processes in the stochastic pi calculus. As a first case study, we show how to express the control of transcription initiation at the lambda switch, a prototypical example where cooperative enhancement is crucial. This requires concurrent programming techniques that are new to systems biology, and necessitates stochastic parameters that we derive from the literature. We test all components of our model by exhaustive stochastic simulations. A comparison with previous results reported in the literature, experimental and simulation based, confirms the appropriateness of our modeling approach.
tcsb.pdf (426.14 Ko) Télécharger le fichier
inria-00089218 , version 1 (12-08-2006)
inria-00089218 , version 2 (13-08-2006)
  • HAL Id : inria-00089218 , version 1
Céline Kuttler, Joachim Niehren. Gene Regulation in the Pi Calculus: Simulating Cooperativity at the Lambda Switch. Transactions on Computational Systems Biology, 2006, Lecture Notes in Bioinformatics 4230 ({VII}), pp.24-55. ⟨inria-00089218v1⟩
Collections
LIFL
152 Consultations
406 Téléchargements
