A proposal for the C++ standard : Bool_set, multi-valued logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Sylvain Pion
Guillaume Melquiond
We propose a design for multi-valued logic, for integration into the C++ standard. The main motivation for this class comes from interval arithmetic, where it can be conveniently used as return type of comparison operators. It also has many other potential applications.
bool_set_RR_INRIA.pdf (164.43 Ko) Télécharger le fichier
inria-00089230 , version 1 (15-08-2006)
inria-00089230 , version 2 (18-08-2006)
  • HAL Id : inria-00089230 , version 1
Sylvain Pion, Guillaume Melquiond, Hervé Brönnimann. A proposal for the C++ standard : Bool_set, multi-valued logic. [Research Report] 2006, pp.22. ⟨inria-00089230v1⟩
293 Consultations
174 Téléchargements
