A method to refine time constraints in event B framework - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2006
Joris Rehm
  • Function : Author
  • PersonId : 756920
  • IdRef : 142454303
Some software or hardware system involves time constraints. When those constraints are required to express the behaviour of the system, we need to write them in the corresponding formal model. We show in this short paper the general method used to deal with time constraints with a simple application example. This applies for event B formal method which does not have specific notions for time and uses the refinement to introduce it.
avocs.pdf (92.06 Ko) Télécharger le fichier
Dates and versions
inria-00091665 , version 1 (06-09-2006)
Identifiers
  • HAL Id : inria-00091665 , version 1
Cite
Joris Rehm. A method to refine time constraints in event B framework. Automatic Verification of Critical Systems - AVoCS 2006, Sep 2006, Nancy/France, pp.173-177. ⟨inria-00091665⟩
103 View
132 Download
Share
