Rule-Based Constraint Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Fundamenta Informaticae Année : 1998
In this paper we present a view of constraint programming based on the notion of rewriting controlled by strategies. We argue that this concept allows us to describe in a unified way the constraint solving mechanism as well as the meta-language needed to manipulate the constraints. This has the advantage to provide descriptions that are very close to the proof theoretical setting used now to describe constraint manipulations like unification or numerical constraint solving. We examplify the approach by presenting examples of constraint solvers descriptions and combinations written in the elan language.
Fichier non déposé
inria-00098476 , version 1 (25-09-2006)
  • HAL Id : inria-00098476 , version 1
Claude Kirchner, Christophe Ringeissen. Rule-Based Constraint Programming. Fundamenta Informaticae, 1998, 34 (3), pp.225--262. ⟨inria-00098476⟩
54 Consultations
0 Téléchargements
