Using Larch to specify the Behavior of Objects in Open Distributed Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
Mohammed Bouchikhi
  • Fonction : Auteur
  • PersonId : 835296
Nacer Boudjlida
  • Fonction : Auteur
  • PersonId : 830690
This paper describes a mediation service (e.g. Trader service), offering to a client (e.g. an object) the possibility to ask the negotiator a service, processing the function that this service will have to accomplish. Our approach aims for a solution based on the functionality of ODP Trader but customised to CORBA. The emphasis of the work is on the solution of problems presented by an open distributed environment. Specifically, our work addresses the handling of: (i) heterogeneity of data; (ii) extension of the existing proposition concerning the IDL with semantic specification allowing the definition of properties on the types of objects and on the disponible services; (iii) determination if two specifications (type descriptions) are related by taking in account the behavior of the types. The paper also describes some details of a prototype for such a mediation service.
Fichier non déposé
inria-00098510 , version 1 (25-09-2006)
  • HAL Id : inria-00098510 , version 1
Mohammed Bouchikhi, Nacer Boudjlida. Using Larch to specify the Behavior of Objects in Open Distributed Environments. Maghrebian Conference on Software Engineering and Artificial Intelligence - MCSEAI'98, 1998, none, 13 p. ⟨inria-00098510⟩
83 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
