Resultants of determinantal varieties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Pure and Applied Algebra Année : 2004
Laurent Busé
In this paper, a new kind of resultant, called the determinantal resultant, is introduced. This operator computes the projection of a determinantal variety under suitable hypothesis. As a direct generalization of the resultant of a very ample vector bundle introduced by Gelfand, Kapranov et Zelevinsky, it corresponds to a necessary and sufficient condition so that a given morphism between two vector bundles on a projective variety X has rank lower or equal to a given integer in at least one point. First some conditions are given for the existence of such a resultant and it is showed how to compute explicitly its degree. Then a result of A. Lascoux is used to obtain it as a determinant of a certain complex. Finally some more detailed results in the particular case where X is a projective space are exposed.
detres.pdf (246.35 Ko) Télécharger le fichier
inria-00098680 , version 1 (25-09-2006)
  • HAL Id : inria-00098680 , version 1
Laurent Busé. Resultants of determinantal varieties. Journal of Pure and Applied Algebra, 2004, 193 (1-3), pp.71--97. ⟨inria-00098680⟩
150 Consultations
267 Téléchargements
