Using projection operators in computer aided geometric design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Contemporary mathematics Année : 2003
Laurent Busé
Bernard Mourrain
We give an overview of resultant theory and some of its applications in computer aided geometric design. First, we mention different formulations of resultants, including the projective resultant, the toric resultant, and the residual resultant. In the second part we illustrate these tools, and other projection operators, on typical problems of CAGD such as surface implicitization, inversion, intersection, and detection of singularities of a parameterized surface.
res-aggm.pdf (322.35 Ko) Télécharger le fichier
inria-00098681 , version 1 (25-09-2006)
  • HAL Id : inria-00098681 , version 1
Laurent Busé, Mohamed Elkadi, Bernard Mourrain. Using projection operators in computer aided geometric design. Contemporary mathematics, 2003, 334, pp.321--342. ⟨inria-00098681⟩
129 Consultations
187 Téléchargements
