Classification problems in object-based representation systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
Amedeo Napoli
Classification is a process that consists in two dual operations: generating a set of classes and then classifying given objects into the created classes. The class generation may be understood as a learning process and object classification as a problem-solving process. The goal of this position paper is to introduce and to make precise the notion of a classification problem in object-based representation systems, e.g. a query against a class hierarchy, to define a subsumption relation between classifications problems, and to analyze the way a classification problem can be solved with respect to a class hierarchy.
99-R-323.pdf (142.88 Ko) Télécharger le fichier
inria-00098788 , version 1 (26-09-2006)
  • HAL Id : inria-00098788 , version 1
Amedeo Napoli. Classification problems in object-based representation systems. International Workshop on Description Logics - Dl'99, Patrick lambrix, 1999, Linkoepings Universitet, Sweden, pp.169-171. ⟨inria-00098788⟩
73 Consultations
61 Téléchargements
