A general XML-based distributed software architecture for accessing and sharing ressources - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
This paper presents a general xml-based distributed software architecture in the aim of accessing and sharing resources in an opened client/server environment. The paper is organized as follows : First, we introduce the idea of a "General Distributed Software Architecture". Second, we describe the general framework in which this architecture is used. Third, we describe the process of information exchange and we introduce some technical issues involved in the implementation of the proposed architecture. Finally, we present some projects which are currently using, or which should use, the proposed architecture.
XmlFinlandeFinal.pdf (79.44 Ko) Télécharger le fichier
XMLFinland.ppt (368.5 Ko) Télécharger le fichier
Format : Autre
inria-00098880 , version 1 (11-09-2009)
  • HAL Id : inria-00098880 , version 1
  • ARXIV : 0909.2145
Samuel Cruz-Lara, Patrice Bonhomme, Christophe de Saint-Rat, Laurent Romary. A general XML-based distributed software architecture for accessing and sharing ressources. XML Finland'99, SGML Users Group Finland, Sep 1999, Helsinki, Finland. 10 p. ⟨inria-00098880⟩
91 Consultations
192 Téléchargements
