Markerless Tracking using Planar Structures in the Scene - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
We describe a markerless camera tracking system for augmented reality that operates in environments which contain one or more planes. This is a common special case, which we show significantly simplifies tracking. The result is a practical, reliable, vision-based tracker. Furthermore, the tracked plane imposes a natural reference frame, so that the alignment of the real and virtual coordinate systems is rather simpler than would be the case with a general structure-and-motion system. Multiple planes can be tracked, and additional data such as 2D point tracks are easily incorporated.
isar00.pdf (357.08 Ko) Télécharger le fichier
inria-00099115 , version 1 (30-03-2020)
  • HAL Id : inria-00099115 , version 1
Gilles Simon, Andrew W. Fitzgibbon, Andrew Zisserman. Markerless Tracking using Planar Structures in the Scene. Proc. International Symposium on Augmented Reality, Oct 2000, none, France. 9 p. ⟨inria-00099115⟩
5326 Consultations
363 Téléchargements
