Counting paths on the slit plane - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
We present a method, based on functional equations, to enumerate paths on the square lattice that avoid a given half-line. The corresponding generating functions are algebraic, and sometimes remarkably simple: for instance, the number of paths of length $2n+1$ going from $(0,0)$ to $(1,0)$ and avoiding the nonpositive horizontal axis (except at their starting point) is $C_{2n+1}$, the $(2n+1)$th Catalan number. More generally, we enumerate exactly paths of length $n$ starting from $(0,0)$ and avoiding the nonpositive horizontal axis, regardless of their endpoint: the asymptotic number of such paths is $4^n n^{-1/4}$ (up to an explicit multiplicative constant). We also obtain limit laws for the coordinates of their endpoint: in particular, the average abscissa of their endpoint grows like $\sqrt n$ (up to an explicit multiplicative constant), which shows that these paths are strongly repelled from the origin. We derive from our results the distribution of the abscissa where a random walk, starting from a given point, hits for the first time a given half-line.
Autre [cs.OH]
Fichier non déposé
inria-00099193 , version 1 (26-09-2006)
  • HAL Id : inria-00099193 , version 1
Mireille Bousquet-Mélou, Gilles Schaeffer. Counting paths on the slit plane. Mathematics and Computer Science : Algorithms, Trees, Combinatorics and Probabilities, 2000, Versailles, France, pp.101-112. ⟨inria-00099193⟩
86 Consultations
0 Téléchargements
