Network Oriented Application Harmonisation
The european standard EN 50170 for industrial Fieldbus recognises three different communication systems. A common open platform will significantly reduce the costs for development, integration and use of automation systems. The main objectives of NOAH are : the specification of Harmonized field Device application and communication interface The validation of specifications through a pilot implementation.
