J TMN : A Java based TMN Development and Experimentation Environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Journal on Selected Areas in Communications Année : 2000
Within the last two years, the Java technology has largely entered the world of element, network and service management and has undoubtedly proven useful in combination with the SNMP framework for both manager and agent side developments. However, very few experiments have been made so far on trying to provide an in depth integration of this technology within the TMN framework. In this paper we present a free software which offers a generic environment which provides a basis for reaching this integration. This environment, called JTMN, is composed of a set of Java software packages which enable both development and deployment of TMN compliant components. Not bound to any specific management platform and easily portable to any TMN system. Its goal is to allow experimentation and deployment of more advanced features such as mobile agents, active network management and advanced delegation in harmony with existing TMN approaches.
Autre [cs.OH]
Fichier non déposé
inria-00099388 , version 1 (26-09-2006)
  • HAL Id : inria-00099388 , version 1
Laurent Andrey, Olivier Festor, Emmanuel Nataf, Radu State. J TMN : A Java based TMN Development and Experimentation Environment. IEEE Journal on Selected Areas in Communications, 2000, 18 (5), pp.664-675. ⟨inria-00099388⟩
139 Consultations
0 Téléchargements
