Fast Channel and Noise Compensation in the Spectral Domain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
We compare in this work several methods for fast adaptation of speech models to convolutional and additive noise. The tested algorithms are Parallel Model Combination (PMC), Cepstral Mean Subtraction (CMS), and an algorithm that combines PMC and CMS in the spectral domain. Experiments are realized on a natural numbers recognition task in French. We have trained the acoustic models on the SPEECHDAT database (recorded through telephone lines), and we have tested the system on the VODIS database (recorded in three different cars).
A02-R-180.pdf (183.91 Ko) Télécharger le fichier
inria-00099440 , version 1 (26-09-2006)
  • HAL Id : inria-00099440 , version 1
Christophe Cerisara, Dominique Fohr. Fast Channel and Noise Compensation in the Spectral Domain. XI European Signal Processing Conference - EUSIPCO 2002, 2002, Toulouse, France, 4 p. ⟨inria-00099440⟩
68 Consultations
68 Téléchargements
