Réseaux Bayésiens Dynamiques pour la Reconnaissance Multi-Bandes de la Parole - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
This paper presents a new approach to multi-band automatic speech recognition which has the advantage to overcome many limitations of classical muti-band systems. The principle of this new approach is to build a speech model in the time-frequency domain using the formalism of Bayesian networks. Contrarily to classical multi-band modeling, this formalism leads to a probabilistic speech model which allows communications between the different sub-bands and, consequently, no recombination step is required in recognition. We develop efficient learning and decoding algorithms and present illustrative experiments on a connected digit recognition task. The experiments show that the Bayesian network's approach is very promising in the field of noisy speech recognition.
Autre [cs.OH]
A02-R-257.pdf (82.44 Ko) Télécharger le fichier
inria-00099452 , version 1 (26-09-2006)
  • HAL Id : inria-00099452 , version 1
Khalid Daoudi, Dominique Fohr, Christophe Antoine. Réseaux Bayésiens Dynamiques pour la Reconnaissance Multi-Bandes de la Parole. XXIVe Journées d'Etudes sur la Parole - JEP'2002, Equipe Parole - LORIA, Jun 2002, Nancy, France, 4 p. ⟨inria-00099452⟩
82 Consultations
167 Téléchargements
